Phone reset
2 replies · 1,982 views · Started 25 November 2007
When I bought my fone (ebay), there already were some apps. I'm not sure if they are part of factory package (EBook, Talkinkg Dictionary, Sudoku, ...).
Will I loose them, if I reset the fone?
For example in private folder, there is 90MB of files belong to the Talking dictionary (TalkingDictionary.mbm, TalkingDictionary.tda, ....), but there is no sis file. Can I somehow backup those apps and install them after reset?
If those files belong to phone software package, no problem. If they are some third part apps, yes, you lose all.
Ok, I've bought new card and wihle copying and deleting, I probably deleted something I shouldn't. Those Apps I was talkin about vanished. If I click on apps mgr there is nothing about them. Bun on the card under private folder, there are still files from them (attached picture). Is there any way to install it back, from those files?
Attachments: allaboutsymbian.jpg
