nokia n95 8gb video res/birate help !!
3 replies · 2,914 views · Started 25 November 2007
Hi can anybody tell me what the Correct video resolution is for converting videos to the Nokia N95 8gb, as obviously its a bigger screen, i need the video size/ birate and framerate aswell if you have it..
Thankyou and hope to hear soon
Brian
If you use Super, 320x240-15fps with 384 seems produce good results.
Hi and thankyou for that, im also using Nokia Video Convertor, do you have correct settings for that, as it only lists the n95 and not n95 8gb, and the sreen is bigger on the n95 8gb..
Thanks from Brian
Biger, yes, but with same resolution, so use the same settings as for N95.
