How do you turn on a-gps ?
7 replies · 2,376 views · Started 25 November 2007
Hi can somebody point me in the right direction on where to turn on/off a-gps assisted gps within the Nokia N95 8gb ?
And also im still not picking any satelites up after doing the firmware upgrade !!
Any help please and thanks from brian
Menu / Tools / Settings / GPS data / options .. POSITION Settings (check/uncheck the methods you want)
Good Luck!😊
Hi and thankyou for that, got it and thats better as all working now, cheers...
Since the phone has to connect to the network to use A-GPS I don't understand why i doesn't also take advantage of the GSM possitioning?
When using Google maps the possitioning feature works pretty well and gets a lock almost straight away without even a sniff off GPS!
seki wrote:Menu / Tools / Settings / GPS data / options .. POSITION Settings (check/uncheck the methods you want)
Good Luck!😊
or Menu / Tools / Settings / General/ Positioning / Positioning Methods / options / open as it is on my phone..
kontraband wrote:or Menu / Tools / Settings / General/ Positioning / Positioning Methods / options / open as it is on my phone..
the preferred method under v20.0.0.15 .. in fact I can't find the old method! 😊
"How do you turn on a gps"
Rub it provocatively and talk about its dirty longitude?
