Help please?
4 replies · 1,506 views · Started 25 November 2007
OK so I searched for help on Google + this site came up.
Checked out a few of the threads but I couldn't find anything that answers my questions, so I apologise if this has been done before!
My phone's suddenly gone AWOL, everytime I try to send a text it says that it can't be done because I don't have enough memory, and to delete some data from my phone memory?
Well, I deleted my Inbox, Outbox, Drafts, Photo's & Songs.
But it's still saying it?
I have about 200+MB left apparently, but it's only doing it when I try to send a message..
Thank you in advance!
:icon14:
Your problem may be related to the amount of free memory available to run programs. This is much smaller than you think, and not related to the 200MB you have free at the moment.
The free memory is taken up by running too many applications at once. Shut everything down and try sending texts. If you don't know which applications are open, hold down the applications key (the "swirly" one above the green key). A list of open applications appears. You can scroll through them and shut each one down.
Alternatively, your Sent Items may be full. I'm not aware of a limit, but there must be one. Note that Sent Items isn't the same as the Outbox.
R
R
Messages in SENT folder get overwritten when the limit is reached.
I have pressed the applications button, and none are running. I have deleted all songs, images and messages and still no difference. I've even tried the factory reset thing, and nothing..
Hmm, maybe it's to the shop then..
rottie wrote:Messages in SENT folder get overwritten when the limit is reached.
There's an option to turn this on / off but either way I wouldn't have thought it'd cause this problem.
