N95 8GB screen
4 replies · 2,117 views · Started 26 November 2007
Just got my N95 8GB and I think I am going to have to replace it. When there is a white screen, like on boot up, there are 4 distinct shadows along the bottom of the screen where the light is uneven. It wasn't like that on my N95. Is this a fault with my phone or are all 8GB like this? Mine is a US import bought from mphone.
On N95-8G I don�t know. But that same shadow appears on other phones, and that does not mean a faulty unit. Go to a Nokia Service and ask them about...
Hi and yes mines the same and its from vodafone, but ive updated the firmware, ie ive debranded it and its still the same, must be a fault with the phone or there again it may just be normal, it doesnt realy bother me that much...hope that helps from Brian.
I also have this shadowing effect which seems to be caused by the lcd leds. Goes away once S60 has loaded up.
