from today 20.0.015 is now available for unbranded handsets, any got it yet?
New Firmware Available
Yes, its avaiable for EURO3 product code for example 😉
I'll have to try this tonight then. The key press bug it really getting in my nerves now!
I'll update at lunchtime if I have time.
I can confirm 20.0.015 is available for Euro1.
mine was bought offline, without any brand to it. Can I update to version 20. ... . ?
hooray nokia! now.. time to back up my contacts etc.. damn its gonna be a long night tonight 😊
Boldly strolling into unknown territory, I am updating as I type this :afraid:
Downloading now! 😃
:icon14:
omg! Please reports on if this includes demand paging please!
Mine is generic and its saying i have the lastest one already 😞
Might have to change my product code
Changing prod code is easy and if this update is all it is supposed to be then getting it is a must.
looks like mine is a
0548364 - 02 CPWH Graphite UK
changed it now, so we'll give it a whirl
30.6Mb of RAM free after a reboot on mine now! (that stupid wizard keeps starting though, so maybe more.....)
After a quick run through keypress bug is NOT evident!
Happy so far! 😃
Early signs are good. On a fresh reboot with Handy taskman I am showing 29.3M free RAM 😊
Other things I've noticed are the search thing on active standby and the N-Gage icon which plays a funky advert and tells you about the coming soon N-gage games service.
Mine's updating now - Always gets your heart racing!!
Mine bricked itself! Tried the three button reset and no joy. Anything else I can try?
i'm installing now 😊
st3ph3n wrote:Mine bricked itself! Tried the three button reset and no joy. Anything else I can try?
try to reflash it, mine just finished and its working thank god.
if nothing works take it to carphonewarehouse
Can't remember if you could do it with the last version but you can now select any video as your ringtone, plays while ringing! Start up is much faster now max 20seconds with pin code!.
Camera works faster with a little "Processing Image" message after taking a shot.
none of my java apps work, i think i need to reinstall.... had loads of java and xsis apps installed
HoundDog wrote:Mine's updating now - Always gets your heart racing!!
Sad, but very true.
It really shouldn't be a risk but it so is!
Right, so what happened was it said I had to recover the phone by taking the battery and charger out, putting it back in and clicking next. At that point it wasn't recognising the phone, but when I moved the cable around it solved that, so now it's got to downloading updates and is in there, but it's taking a while.
Any idea how long it should take?
The download will depend on your connection speed (mine took about 10 minutes) and the install takes about 15 minutes
Just noticed the radio icon has changed to a nice little boombox icon (much better)
yeah.. it takes about 25-30minutes with downloading and installing.
it works with the apac codes!! and so far so good... now i gotta put all my old programs back in
i think the keypad bug is gone!!!!
awesome stuff 😊
Does your PC/Nokia Software Updater recognise it at all?
I had problems with an N80 and had to run through the Updater a couple of times before it eventually "came back".
Looks like somebody's dad lied about v20 not going to be released 😉
I wonder when they'll release an update for the N95-3.
is demand paging built in ? Someone please confirm otherwise im not going to update straight away.
thanks
regimorales wrote:Looks like somebody's dad lied about v20 not going to be released 😉
Ooh you bitch :laugh:
nudda wrote:is demand paging built in
It probably won't show on the phone, I can't find it. We may have to wait for the change log.
