Can anyone help please.
Just updated the firmware,
updated ok it fine. But dont have wap settings for vodafone.
tried vodafone settings but not working.
also tried nokia site not working.
anyone got settings for vodafone n95 8gb
thanks in advance
thanks in advance
Go to
menu>tools>utilities>settings wizard
Steve
tried setting wizzard nothing happen
Kal, if you go to the Vodafone OTA Configurator and enter your mobile number and then click 'submit,' we'll send the settings to your phone. This will get your MMS, WAP and Internet working correctly.
Hope this helps,
edwardpeter
kal wrote:Can anyone help please.
also tried nokia site not working.anyone got settings for vodafone n95 8gb
thanks in advance
What do you mean by "not working"?
What happens when you go to the Vodafone website and ask for the settings to be sent as an SMS message? Do you not get the message, can you not open it? Are the settings not saved? Do they not work when saved?
Did you restore Settings after the Firmware upgrade? If you did, do a full format of the phone as restoring settings this is not a good idea. *#7370#. It will wipe everything on the phone just like the firmware upgrade did. Restore contacts, Calendar and Messages if you like but not Settings.
The Connection Setings are normally read by the phone from the SIM card.
