Deamand Paging
4 replies · 1,719 views · Started 27 November 2007
ive came across people mentioning it a few times. what exactly is it?
you will probably get 20 different explanations 😮
Demand Paging
In Virtual Memory Systems the pages are not loaded in the memory until they are "demanded" by a process; hence the name, Demand Paging. Demand paging allows the various parts of a process to be brought into physical memory as the process needs them to execute.
In virtual memory systems, demand paging is a type of swapping in which pages of data are not copied from disk to RAM until they are needed. In contrast, some virtual memory systems use anticipatory paging in which the operating system attempts to anticipate which data will be needed next and copies it to RAM before it is actually required. For a process to execute, all the structures for data, text, and so on have to be set up. Pages are not loaded in memory until they are "demanded" by a process. Thus we get the term "demand paging." Demand paging allows the various parts of a process to be brought into physical memory as the process needs them to execute
best read this:
http://en.wikipedia.org/wiki/Demand_paging
And the effect of that is: programs both use less RAM to run (since they don't have to load the entire program into memory if not every part of it is in use), plus they load faster (since it's not taking time to load everything into RAM). More effective RAM plus more speed makes it pretty much the best thing to come to the N95-1, since 'out of memory' errors were one of its worst problems.
