USB Cable
10 replies · 2,224 views · Started 27 November 2007
my USB cable has suddenly stoped working. when i plug my phone in nothing atall happens. i have tried changing USB port and still nothing. it was working fine up till now?is this something simple?
sometimes the USB goes err awol ..
a reboot usually fixes. .. good luck! 😊
u were right my usb was off its tits for a while! just tried it an it started working.brilliant!
I have the same problem. Apparently many others have it (in Nokia Support Discussions).
USB stopped working after the upgrade. I could only connect once and then nothing happens. I reflashed the new firmware, it worked for a while and then stopped again. I've rebooted many many times pc and phone. It's definitely a bug of the new firmware.
Ok this is a joke. I have rebooted the phone about 15 times and the pc 3 and it STILL will not pick up the usb cable. Everything else is the same so it must be a firmware bug. Grrr, just when things were looking so rosy
Do you have Rotateme Beta 2?
Remove it and remove the battery for 30secs.
Mine now works fine. I installed the beta 1 of rotateme and all is fine.
Something is not right with new firmware and rotateme.
I've never had a problem with my USB cable, it connects everytime.
I haven't installed rotateme, so can't comment on that. So in a way that could be it.
ph7 wrote:Do you have Rotateme Beta 2?
Very interesting. I do have the rotateme 2nd beta. I'll try ditching it now and see if it fixes owt
Apparently others have also reported it to Samir. He has now completed beta 3 which tries to deal with the USB bug. If you know French (or you can use a tranlator) read on here.
mine is ok after i reboot the phone but its really annoying!it never done it with the old firmware when i had rotate me though?
I have removed it and installed beta 3 which I received last night. All seems ok at the moment
