Hi
I am about bemused about the varying reports of how much free ram i should have.
I only have nokia device status installed, and i get a report of 56mb of RAM and 25mb Free......
Other users are reporting 30mb free?
What gives?
Hi
What gives?
I had 30mb free yesterday after a reboot (once I had uninstalled all the wizards and all that crap). However, checked today and it is down to 26mb after reboot, but I have installed themes and all my apps etc now, so I would suspect that is normal.
Steve_R wrote:I had 30mb free yesterday after a reboot (once I had uninstalled all the wizards and all that crap). However, checked today and it is down to 26mb after reboot, but I have installed themes and all my apps etc now, so I would suspect that is normal.
Hi..What software do you use to check the mem and what have you uninstalled??
Gary
I have handy taskman reporting 25.4 currently with just rotateme (beta 2) running and everything installed.
Handy taskman here too, but I also have nokia device status installed as well.
I just went into the applications folder after installing the new firmware and uninstalled the stuff I dont use. Such as the settings wizard etc etc:icon14:
