V20 - Videocenter can find "my videos"
9 replies · 2,251 views · Started 27 November 2007
I have 3 videos placed in my "My Videos" folder on my memory-card, they used to show up automatically in the VideoCenter app, but now they are nowhere to be found (they are still in the folder but VideoCenter will not show them).
Anyone having the same problem?
I put my card in a card reader and deleted the "videocenter" folder located under "Data".
I also deleted everything in the "Private" folder (not sure if that is needed)
Now it works as before 😊
Peter321 wrote:I put my card in a card reader and deleted the "videocenter" folder located under "Data".
Well done Peter321, I just deleted "videocentre" and normal service was resumed!
Cheers,
s.
seki wrote:video folder instead of "my videos" ..
That didn't help, only now they showed up in the Gallery, and I prefer to keep them separate, which is why the videocenter is nice - it also keeps track of how much you watched so you can pick up where you left off.
The trick mentioned above was what it took, and it now seems to be working normally.
