Muvie Application na N95
3 replies · 1,300 views · Started 27 November 2007
There used to be an application on the N95 that allow you to make a movie based on image, video and audio .. But I can not find it after last firmware update v20.0.014 .. any idea ?
Did they remove that!? It's not supposed to be on the new N82, but they can hardly remove it from the old N95-1s with the SU!
Doesn't look like it availalbe in the latest firmware :con?
Seems stupid. It used to generate a lot of memory errors so perhaps they though 'If it's not there at all, it can't cause problems'.
Ironic really considering demand paging would probably have fixed the errors anyway
