Truphone not connecting after v20
3 replies · 2,046 views · Started 27 November 2007
Hi Guys hoping someone can help.
After updayed to v20, i insalled all my software, but truphone does not seem to work, when i try and connect to it , it says " unable to connect to the network connection".
Can someone help as i use tryphone alot,
Have you checked all your wireless settings - mine had a bit of a funny where it couldn't see the network, but rebooted the router and phone and all is ok now. Have found that post v20 it seems to be murdering the battery though (totally dead in less than 12 hours having made only 1 call for about a minute or two). Will try turning voip off and see if it improves.
xio wrote:Have you checked all your wireless settings - mine had a bit of a funny where it couldn't see the network, but rebooted the router and phone and all is ok now. Have found that post v20 it seems to be murdering the battery though (totally dead in less than 12 hours having made only 1 call for about a minute or two). Will try turning voip off and see if it improves.
Have you got truphone working on v20?
