data byte counter? and WLAN WEP key problem
1 replies · 5,013 views · Started 27 November 2007
hi there,
I'm looking for a data recorder, which can record how much kb's are sent via my WAP connection. Is there anyway to do this?
Also My 128bit key in my WLAN is too long by 2 digits - is there anyway around the problem?
Thank you
The connection manager app does this for active connections, and the log app will tell you all activity and how much traffic in both directions once the session is over.
[top tip] When you first start using all the different internet-thirsty apps on the E90, set one of the "my own" keys to the connection manager - that way, when you see the connection icon flashing in the corner, you can quickly check how much data its using, and where its accessing. Sometimes its only a few kbs, from things like A-GPS, but other times its a torrent of data for things like google maps with the wrong access point set. :icon14: [/top tip]
