Hi!
Just traded my N80 for an N95, and am generally satisfied. Was wondering if anyone knows of an app that deals in Soccer Stats. I know that my old XDA had one but this was Windows based. Sort of thing I'm looking for is weekly updated league tables, downloaded from the web, and then I can analyse at my leisure when I'm travelling.
Secondly, is there a TV Listings app out there. Again, the Radio Times used to do one, but not for S60 3rd.
Any help is always gratefully received!
Thanks,
stirly wrote:Secondly, is there a TV Listings app out there. Again, the Radio Times used to do one, but not for S60 3rd.
If you have Sky+ at home you can download their remote record app, that has all the listings and you can press 'Record' and it'll set your sky+ box to record the programme.
Point your mobile browser to mobile.sky.com/skyapp/skyapp.asp
Thanks Hound Dog! Have got Sky+ at home and use the app you mentioned. What I was really looking for though was some sort of downloadable TV Listings, where I could browse them without being on line.
Thanks for the input though!
No worries dude, I don't know anything that does what you're after. I just use the Sky app, not the fastest of apps though.
Digiguide do a downloadable TV listing, which I think you need to sync via avantgo. I used it for a while but then stopped when I had the Sky Mobile app, as this gives TV listings in a much neater format (and also has the benefit of allowing you to record a program you see).
Is there nothing in Widsets?
There must surely be an RSS feed around somewhere?
