Since upgrading my N95 to the new firmware, im not able to install yahoo! go
anyone else having this problem?
whenever I try to install it, just just comes up with "unable to install"
on my old orange branded firmware it worked fine
I have an similar problem..I cant run the app, and moreover, I cannot remove it either..Its on my memory card..
Me too. I think it's if you had it installed on the memory card when you updated your firmware.
See my notes in this thread.
It's not that. It was installed in my phone's memory and in any case I formatted the memory card before the upgrade.
Still having exactly the same problem, though. Tried some searching for an answer but it's early days yet and didn't find anything helpful.
