Severe n95 spaz out
1 replies · 1,277 views · Started 28 November 2007
Well.... installed fring on my n95 with latest firmware (onto the phone mem unfortunalty), 2 seconds after i closed fring the phone started going mad, trying to dial numbers and opening the gallery and flicking through it randomly, wont take any input from the keypad or the likes... even turning it on holding *,3,green doesnt work.... Its insured and could see the hard side of my kitchen floor unless anyone has any suggestions?
Cheers, Peej
Does it still connect by Data Suite when you hook it into the cable?
If so then use NSU to force a re-flash. someone might have an easier way though.
