Hi! Have just upgraded to the Version 20 firmaware, and now have the Search function bar on my Homepage. Is there a way of removing this, as it is not a function I use and it's just taking up space?
Thanks!
Thanks!
I wanted to start a thread about this too but the 8 or 9 previous times it has been asked made me decide against it 😊
3Shirts wrote:I wanted to start a thread about this too but the 8 or 9 previous times it has been asked made me decide against it 😊
I bet you wish you had now :tongue:
Join in the fun.... LINK
I would be interested in knowing the solution for this, if there is one
Uninstall the search application is one solution, another is to remove everything from your idle screen and use the buttons to launch your favorite applications instead.
dchky wrote:Uninstall the search application is one solution, another is to remove everything from your idle screen and use the buttons to launch your favorite applications instead.
You cant uninstall the search option in v20. its part of the firmware. Your latter suggestion tho would work...
BUT YEAH, this question has been asked many times! Do a search.
