N95 upgrade .. v20 problem
7 replies · 2,184 views · Started 30 November 2007
the date is 20 mov, 2007 n it says v12 is the latest...
wht do i have to do...
i am using Airtel , India... GSM
You have to possible change product code, using NSS to be able to upgrade. Not sure if its available inIndia yet.
2 choices
1. wait for the update to become available for your product code
2. as ferale has said you can change your product code and then update
im using a simfree N95 in the u.k and i cant get the update yet either
ok... some one point me to the tutorial to change code n upgrade it ?
