Can't delete software on 6120
2 replies · 3,378 views · Started 30 November 2007
I've installed a downloaded program using nokia pc suit on my cell.
unfortunatlly the software had a problem during installation and now i can't remove it.
I don't mind losing any other data, just want to get it of the cell, PLZ HELP.
I used this advice by uthar : "You can reset all (format) by turning it off (and remove sim and memory if you want to keep the data) and hold green+star+three (dial * 3) while turning it on. Be sure to backup data you want to keep (with Nokia PC Suite)."
which worked gr8 (if you dont mind losing some data).
thanks alot!
