Hey All,
Was wondering if anyone might be able to help me with an issue I have on my phone.
If I turn the phone off, then turn it on again, I get a bar that pops up that says; "Installing"
This is then followed by;
Untrusted software found on memory card. To Uninstall, goto application manager.
I have been into the app manager and there would appear to be something in there called f01fbd20.sis, with a status of "Not Installed"
I've tried removing this from the app manager list but had no luck.
If I try to install this app, it says that I am trying to install "Contacts Transfer" ???????
Never heard of it ?
Help suggests that to uninstall or get rid of software, to press the "c" button.
This doesn't work.
Anybody got any advice ?
Cheers,
Scott
