E61 wifi users, I have a question for you
4 replies · 2,782 views · Started 30 November 2007
Can someone confirm if any of the following features can be done on the E61 using wifi only with no data plan:
-AOL/MSN/Yahoo instant messaging
-Web browsing
-IRC
Thanks!
You mean use the WiFi instead of data plan? If so, yes, you can use the WiFi for all the stuff you mentioned.
Yes, using wifi only with no data plan.
Is third party software required to run these functions over wifi?
As ares mentioned, for IRC and messengers you'll need 3rd party software. Nothing to worry about, there's alot of freewares for that.
