Cannot Upgrade to V20 for N95
8 replies · 3,375 views · Started 01 December 2007
Hello All i am using Nokia N95 and came to know tht V20 firmware is avaliable to upgrade But while connecting my Handset with Nokia Update software i cannot see any updates avaliable for my set. It Says i am running V12 and thts the latest version avaliable. PLS help how can I get the latest V20 ...
I am from India and bought the handset from India ???
Are updates not available for indian/asian users still is it sumthing like tht is thr ne way around to get the updates...
ne help will be gr8tly appreciated..
i just found out my product code is 0548986 - India ..... does changing it will help me in ne sense ???? pls help ... am desprate to get V20 after coming to knw all its features esp ... the demand paging thing
Changing the code to EURO1 will get you the upgrade as its not out for APAC code regions yet, but im not sure how it will handle languages.
does changing the code will cause ne damage to the handset... in case Nokia dont give me warranty... ne time whn this upgrade will be avaliable for APAC regions thnx for replying
I just changed my code to scandinavia and got the update without any problems
... the code I had before wasn't listed, was a bit weird since it's bought in a shop in Sweden, unlocked and without a subscription, but oh well, after changing it to the scandiavia code listed in the stickie post it worked just fine.
kus234 wrote:ne suggestion guys
Here is one: Search! 🙄
There are countless threads about changing code and even a sticky tutorial right at the top of the forum which tells you how, why and the risks!
kus234 wrote:Hello All i am using Nokia N95 and came to know tht V20 firmware is avaliable to upgrade But while connecting my Handset with Nokia Update software i cannot see any updates avaliable for my set.
