Unhide Z:
13 replies · 2,917 views · Started 27 February 2002
I made this new thread for this one (from community waffle), and i hope we can find some other interesting stuff from this "unhide"
I mean getting access to delete/modify files on z <B>if</B> there is some way..
If anyone knows what common there are in these codes.. the result is same (settings>show rom) but what else
++SP
++DP
++VP
++LP
If we can find other key compinations?
I found
++version
++date
Don't ask me what good they are (apart from the obvious), but they're there....
In what other applications are they likely to exist?
Maybe they're called <B>Volkerscodes</B> (I found that encoded near the other codes)?
I don't fancy trying a code that contains a <B>BCKSPC ENTER</B>!
<font size=-1>[ This Message was edited by TANKERx on 2002-02-27 1441 ]</font>
I think he's cracking a joke about it deleteing a file.
/me tries the usual UP,UP,UP,LEFT,RIGHT,UP,LEFT,LEFT,DOWN,A+B+C cheat User posted image
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
On 2002-02-27 1515, JeP wrote
��yyhh... i see.. But i need to get access to delete/modify some files..
JeP
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Yup! Sorry if anybody tried it! User posted image
Sorry I haven't replied sooner. I can only post from <I>somwehere else</I> at the moment since my computer is currently in a transition from XP to Linux (sorry Switchblade, I almost went to BeOS, but I got pulled farther down the shelf at the last minute User posted image )
Anyway. I downloaded <B>frhed</B> from -> http//www.geocities.com/frhed/ , copied the File Manager files to my PC, loaded the .app file into <B>frhed</B> and did a search on some of the codes already mentioned.
Within <B>frhed</B>, do a search on <B>+'<I>Smaller Than</I>' bh00 '<I>Greater Than</I>'+</B> and you'll be taken to the Volkerscodes (?).
<I>sorry about the faffing in my typing, but I don't know how to do the pointy brackets without having to disable HTML - I'm a bit simple you see User posted image but happy User posted image </I><font size=-1>[ This Message was edited by TANKERx on 2002-02-28 1138 ]</font>
Linux, ha ha ha ha ha..... You are going to have days of fun there, especially if it's your first linux installation User posted image When after 2-3 days you are still totally lost grab a copy of BeOS, trust me it's simple, even an M$ Luser could understand it.
BTW &GT = & G T
and &LT = & L T
remove the spaces obviously User posted image
On 2002-02-28 1446, SwitchBlade wrote
Linux, ha ha ha ha ha..... You are going to have days of fun there, especially if it's your first linux installation User posted image The first Linux installation I did was with a friend on a 486 box we had spare so we could say we managed it, it took us 2 weeks to get it running so that we could get X & KDE on it User posted image Though distributions have gotten a bit better in the last 2 years.
BTW > = & G T
and < = & L T
It's Ok. I've done it a few times with less friendly distributions so this one should be easy enough...... if I'd only remembered some basic IT when I tried setting it up last night, I wouldn't have trashed my XP setup User posted image
Never mind. As we say in Wales; "Dyfal donc"
They say all things happen for a reason, at least for you it was a good thing User posted image
WindozeXP - just when you thought things couldn't get any worse....
