I spotted this on eBay and was thinking of getting one. It doesn't charge from the USB but it connects to the PC while charging up which would help me a great deal. Has anyone else got one or tried one?
USB Charging Cradle on eBay
Hi there mate.
I have personally bought this one:
http://cgi.ebay.co.uk/Advanced-USB-Desktop-Sync-Station-Dock-For-Nokia-N95-UK_W0QQitemZ160185195704QQihZ006QQcategoryZ20368QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
It's powered via USB, and also has an SD slot, spare battery port (haven't used this as I don't trust it not to 'overcharge'😉
Also it has an USB-out port (to plug in more devices, which is handy)
It seems to charge the phone just fine, and as an added bonus it charges via USB, and it uses the phones USB port to connect (PC suite etc)
It also comes with a multivolt AC adapter (UK 3 pin)
Hope this helps
Andy
Thanks, yes I spotted this one as well. I decided it wouldn't be for me because I already have a card reader in my PC. Looks the stuff though, huh? 😊
zxon wrote:Thanks, yes I spotted this one as well. I decided it wouldn't be for me because I already have a card reader in my PC. Looks the stuff though, huh? 😊
Yeah it's not too bad mate, I'd definitely recommend it!
Andy
Is the spare SD Slot SDHC compatible? or just standard SD?
I'm dying for a craddle on my phone.. want two - one for home and one for work.. 😊
bchliu wrote:Is the spare SD Slot SDHC compatible? or just standard SD?Thanks
Hi mate, just tested it with my SDHC 8GB and it works fine
HOWEVER
It is not a microSD slot, jus a standard SD, so youll need the adapter
Andy
