backlight and video player
6 replies · 2,167 views · Started 23 January 2003
im trying to play clips full screen in video mms but the light goes out, using torch in the background doesnt work. any other ideas?
There are some other applications like file explorer 1.06 that have the function to tur the backlight always on. So if you have any of this programs, (file explore is free) you van run the program, switch the backgroundlight to "always on" then run the application in background and the light should remain always on untill you close the program.
You can try this. It works fine on my nokia.
How do you play video on your gsm? Can you stream them from your pc?
tried fexplorer same thing, im using wind videomms camcorder app to play mp4 files fullscreen, light still goes out its ok when not in fullscreen but i want it on fullscreen! :d
maybe u missed my first reply! have tried torch it does not work in full screen mode light goes out 😞
Well the only remedy I know is to push the voice tag/handsfree button on the left side of the phone. It keeps the light on without removing the fullscreen of your videomms prog.
