phone freezing for a few seconds
6 replies · 2,019 views · Started 02 December 2007
has anyone else noticed this especially while browsing the net.when waiting for a page to load the light times out then i press any key get light on and the phone will not respond atall for a few seconds
My phone is also freezing, sometimes very long. Does anyone else got this problem?
Regards,
Bigningbo
mine also does the same ... starting happening after upgradin to v20
Did you restore Settings after doing the firmware upgrade.
Restoring Settings between different versions and Variants of firmware can cause problems. Contacts, messages etc are fine. Try a full phone format (*#7370#) and seee if you still have the fault.
Thx for tip, it doesn't help in my case. Now my N95 screen is compeletely freezing. It is unusble now, have to leave it to the service center. Very strange, are there anybody got this problem too?
Regards,
Bigningbo
have just noticed more times than not the phone is still working but the light takes about 3 or 4 seconds to come back on. So its not actually freezing all the time its more the light being slow. Also i never restore from back up after firmware upgrade, it kinda defies the point. And tried hard reset just to make sure but still the same.its not un bearable but annoying
