NSS Can't find my phone.
9 replies · 4,637 views · Started 03 December 2007
I have an N95 8GB and I wan't to change to product code to be able
to upgrade firmware.
I've installed Nemesis but when I search for devices it does not find a device.
I click on the magnifying glass, it thinks for a bit and then nothing, the button
becomes clickable again but no devices found.
Any ideas?
Ta,
Nick.
southglade2000 wrote:Hi,
Any ideas?
Ta,
Nick.
Right click pc suite in your system tray and exit before you connect your phone. It doesn't seem to like pc suite running at the same time.
Also, do you have the latest version of NSS, I had to upgrade to v1.0.38.12 to get it recognise my girlfriends E65.
Yup, done both those things. I don't understand the bit about re-installing drivers at the end. What drivers should I re-install?
I didn't have this problem when I did this to my N80, and I've just plugged that
in and it's not finding that either.
(I uninstalled NSS after updating my N80 n months ago...)
Thanks again!
Nick.
There's no drivers to reinstall. When you're installing NSS, make sure you choose the Virtual USB driver.
HoundDog wrote:There's no drivers to reinstall. When you're installing NSS, make sure you choose the Virtual USB driver.
Got it! Thanks for all the help guys.
i didnt get asked to install virtual usb browsers...
it found the n73 though and broguht up product code so presume it has installed ok?
Still doesn work for me. i installed nss with virtual usb. connected the phone in pcsuite mode closed pc suite but still nss wont detect my phone
Found the answer in another thread... if you have vista run it in XP compatibility mode and as administrator... thanks
