Q. I'm having lots of problems with random errors and disconnections when using Wi-Fi on my smartphone. I've heard that turning off 'power saving' helps, but I can't find a setting for this!
I was trying for ages to use my mac as WLAN while stuck with a cable connection in the states. I got the dreaded Bad Gateway response numerous times :con? before trying this tip. Now its perfectly stable! Thanks Steve 🙄 :icon14:
You post the link like a spam
What kind of problems are you having? You cant start a new thread at all, or your thread is getting deleted? What is the topic of the thread you are trying to start?
Hi, I have used my Hummy 9200t for the last three years, and am now about to add a Foxsat HD to make full use of my Toshiba 1080p LCD TV.
I have been in the habit of turning off the power at the wall socket for all equipment when not in use overnight, the question is can I do this with the Foxsat without any problems.
Hi Friends,
Yes you can do this without any problem with foxet.
I have tried already so I am telling.
Try it if find any problem pm me.
