T9 Functions in V20
4 replies · 2,271 views · Started 03 December 2007
I updated from T mobile version 12 to version 20 today...
Majority is good in the update, and clearly the phone works much better.... but... two small problems
1) Previously when writing a text with T9 enabled, the scroll of dictionary was controlled by the down portion of the keypad - but it seems to have now changed to the * instead since updating to V20.
Anyone know of a way to get this back to the down button just for convenience?!?!?!
2) The search function on the mainscreen doesn't seem to work - any ideas welcome!
Cheers
It did that on mine when i upgraded to v12, must be something T-Mobile-ish about that setting, but yes it was very handy.
I assume you were on T-Mobile firmware and debranded? They really should put that in the generic firmware.
It wont reappear until T-Mobile officially release v20.
Its one of the most bloody annoying "tweaks" they made as when your scrolling though the message or entering text into a multiline box you have to keep ressing right and then down otherwise it starts altering your words.
Major pita its worth debranding just to get rid!
