nokia n95 went into local mode
1 replies · 5,511 views · Started 04 December 2007
hi all if you can help phone has gone into local mode with a black screen ,
i tried to change product code , think i f##ked up , it has now turned off .
thanks for any help you can give .
was u using the nokia software updater? If so turn phone off and hold green call key, the * key and 3 key and while holding them hold the power key, hold the 4 keys until the handset asks for the time/date etc, hope it works
