How can I get the phone to keep the configuration of the software when I remove the mini SD card? because right now what is doing is that if I remove the mini sd and when I put it back I need to reinstall all the software. is kind of annoying to do this, does any one have any suggestion???
When removed the SD card all software gets uninstalled
That's because you installed the software to the memory card, I reckon.
right!, but I can't install it in the internal memory either..... what if I put the phone as offline and then remove the SD card
netof_100 wrote:right!, but I can't install it in the internal memory either..... what if I put the phone as offline and then remove the SD card
Eh? That sounds a tad silly.
When you install an application (for the first time, that is), you get an option of where to install it - internal memory, or the memory card. Select memory card.
can u not 'uninstall' it from application manager? then might try install it.
btw, what software is it?
