MobileTracker for BlackBerry - save 30%
0 replies · 4,277 views · Started 04 December 2007
MobileTracker for BlackBerry - save 30% from PDATopSoft.com
http://www.pdatopsoft.com/software/item.php?pid=12720
Recording a Tracklog:
MobileTracker has been designed to be as easy to as possible. Within 2 easy steps you can start recording a tracklog: 1. Start
MobileTracker; 2. Press the start button to start the recording. Moreover, you can select the delay that should be between every
recorded point of your tracklog. This allows you to adjust the recording to your movement.
One more button click is needed to stop the recording and save the tracklog to the specified location.
Integration:
All of MobileTracker's information can be quickly viewed in Google Earth's� 3D view. It is even not necessary to copy the tracklog
file from the device. The BlackBerry� can be easily connected to your desktop computer. By selecting the directory your tracklog has
been stored to, you will immediately find your tracklog. Double clicking on it will automatically open your tracklog in Google
Earth�.
Blackberry Games
