NSU doesn't find the phone
7 replies · 1,782 views · Started 04 December 2007
mmmh...what the f***... I tried to upgrade firmware but NSU doesn't find the phone.
Productcode-Changed (Scandinavia) CHECK
Antivirus-off CHECK
PC-Suite-off CHECK
PC-Suite-mode on phone CHECK
No phone found... 😮
Tried a different usb-port but still doesn't work.. :icon4:
Same here, tried a lot of times bus NSU won't see the phone(unbranded/not locked)
Pc suite does see the phone
Reboot PC, don't run PC Suite, turn off all AV and firewall.
See if you have PC Suite icon in the System tray (next to the clock), if so, try right-clicking it and Exit.
Connect Phone in PC Suite mode, make sure it is detected but don't run PC Suite.
Then try Start, Pograms, Nokia Software Updater.
andykn wrote:Reboot PC, don't run PC Suite, turn off all AV and firewall.
DON'T use the NSU that is IN the PC Suite .. use the separate one I linked above.
Good Luck!😊
Is there a NSU in PCsuite? Mine only opens the Nokia website
Hydetys: please post if it works now,
I'm waiting for word on the calendar problem in another topic before trying to update again😊
