6110 colours
2 replies · 3,392 views · Started 05 December 2007
Theres a fair few colours on ebay, but has anyone taken the 6110 apart? Might be bit of a job to fit new facias on.
Also, I cant see any that come with different coloured keypads, they are all black.
I fitted a white cover for the Mrs 6110 phone. It was a genuine Nokia one so fitted fine. There is one Torx T6 screw under the "GPS" sticker on the back of the slide and with a plastic case opening tool its easy to do remove the cover.
I had tried a cheap copy cover but it was so badly made it was scratching the keyboard when opening the slide so stick to the original Nokia ones.
Look for a seller on ebay called First2save. They have keyboards,covers and replacement S60 keypads. Excellent service and reasonable prices!
