Hi....i just got a nokia 9210i and i wanted to know that by default all my downloaded material (from infrared, pc cable etc) goes to the downloaded section of my communicator.......can i set the mmc card as default? i mean if i want that all downloading should go to mmc instead of my communicators normal memory, is that possible? also, i installed pc suite on my comp. but how do i browse thru the files in my communicator via my pc? i have tried going thru windows explorer but there is no icon for the communicator? will this icon appear only after i have backed up my communicator files to the pc?
please help me....nokia 9210i mmc!!
You can select the memory. When you correctly install pc suite you should see an icon of the 9210 on your desktop. After you are connected press the icon and it should open the window where you can brows throgh...hope to have helped. :P
as Godfather said.. you can browse your communicator after installing the PC Suite
and in the communicator, you can set your default folder from Control Panel ==> default Folder, you can choose MMC there.
Good luck 😉
😃 that REALLY helped!
