predictive text app?
1 replies · 2,365 views · Started 08 December 2007
the other day i was browsing some software for my n95 and i found an app that lists possible words, so u don't have to type out the entire word & then scroll through the possibilities.
so for example, if you want to input the word 'test'...you might just have to enter 8 & 3 for 't' and 'e', and this program would have a small drop down listing possible words you want...test being one of them.
today i've been searching for close to an hour and i can't find it, does anyone know of that or any other software that does that?
thanks
I think the one you're looking for is Adaptxt but it is only a beta release at the moment (and if you use skyquikey, they don't like each other).
