now we can sign our apps directly on our mobiles.......
you need the .key you used to create your .cer file at symbiansigned.com and put the key and cert on your phone, open the app and select an app to be signed, your cert and .key and input the password, then select sign, your new signed app will have a .sisx extention, then just instal.....
link to file and key ... http://www.savefile.com/files/1251222
however a pc (or nice person) is still needed to make the certificate with pc tool and upload it to symbiansigned, the .key i have provided in the archive above uses [COLOR="#ff0000"][COLOR="Blue"]0123456[/COLOR] as the password[/COLOR]
__________________
Great idea! Can't wait to try it out 😊
i got this yesterday have been trying to sign an app for days (rotateme2.0) managed to create an account on symbiansighned, used this and it worked!!
so so easy to use even for a n00b like me.
now im off to symbian rehab .....................................😮
Mine won't work for some reason. I've signed apps on my pc for a month or so now with no problems, but when I use this app it's proving troublesome.
I put my key and cer files on my memory card, and also an unsigned app (rotate_me beta3). For starters, when I use the "Sign" option it throws up an error reading "Error Load Key File!". When I use the "SelfSign" option however, it works and shows "Operation Success!" instead. Unfortunately, when I try to install the signed sisx file it makes, I get the error "Unable to install a protected application from an untrusted supplier".
These same key and cer files work fine on my PC so why doesn't it work on my phone? Any help would be appreciated.
are u using the binpda.key by any chance or a key with a dif password than 0123456? The keys with password 0000 dnt work at the moment
Nah, I'm using a key that I made myself. The password for it doesn't have any numbers in it.
how to get cert file please
