Hi.😊
I just ordered Route 66 Mobile 7 for Symbian S60 V2/3, with Scandinavian maps, to my N80, I installed it and it works just fine.
But then I taught I�ll upgrade My Route 66 trou the ROUTE 66 Sync prog, in hope to get an update of the maps, security cams, voices.... but .... noop.:frown:
The program just reports "your device is not connected to the PC".
I�ve tried all of the 4 different connecting modes, but noting helps.: mad:
Can anyone of you guys out there in cyberspace help me pleeees :redface:
Roy
Hi.
Me again, my Rout 66, are still working fine, just some minor problems.
It seems to have problems with interference from other BT devices when I am in stuck in traffic, the connection with my BT GPS receiver comes and goes.
If you guys have any solution on my prior problem regardless witch map u are using, pleees post her.
Roy
What version of firmware is your phone running, I recall the early versions had a bug in bluetooth that meant it dropped teh connection regularly.
type
*#0000#
on your phone and post what version it is running
Hi entwisi.
My phone reports that I'm running
"V 4.0623.0.42"
20-09-2006
RM-92
Nokia N80 (40.01)
Berro62 wrote:Hi entwisi.My phone reports that I'm running
"V 4.0623.0.42"
20-09-2006
RM-92
Nokia N80 (40.01)
Upgrade your firmware with Nokia software updater ... that should solve your problems, as the previous poster says, there were issues with BT and older firmware
