Hi Folks,
does anyone tried to open the device in order to look into the interior of the phone. I have noticed that under the cover of the battery there are two screws. I wonder if these screws are the way in order to open the device. Want to get off the whole plastic arround the phone so that I can built my own screen protector which will then fit by 100% -without any boubles etc. etc.
Any idea?
Bugfrog
How to open the P800
The top portion of the back cover around digital camera is also detachable and there are two more screws under it. Open it the way you remove the keypad.
I don't think opening it is such a good idea :roll:
well you know what...that really is not a good idea...even if it means that you get a better fit on the screen protector.....i would rather have a screen full of scratches than a P800 that has gone wrong.....
There always has to be one...
😮ops:
You know, when you get something new, you really want to "explore" it as much as you can, sometimes even without any constructive purpose!
I still remember when I disected my 8890 two weeks after I got it and it's still working like a charm after two and half years. Meanwhile, all of my friends' are breaking apart! 😃
[quote="bugfrog"]Hi Folks,
Any idea?
Bugfrog[/quote]
If You open the phone, please take pictures about it's internals and post it to the net. It would be very cool to see how it has been built and what components are there. Guide to open p800 would be cool too. Do anybody know if there is allready such pictures and guides on the web?
If you want to see the inside of your P800 go to the FCC test side:
https://gullfoss2.fcc.gov/cgi-bin/ws.exe/prod/oet/forms/reports/Search_Form.hts?mode=Edit&form=Exhibits&application_id=729690&fcc_id=PY77130501
[quote="frei"]If you want to see the inside of your P800 go to the FCC test side:
https://gullfoss2.fcc.gov/cgi-bin/ws.exe/prod/oet/forms/reports/Search_Form.hts?mode=Edit&form=Exhibits&application_id=729690&fcc_id=PY77130501[/quote]
Wow, thanks, that was just what I wanted
Here is another one
http://www.dreamsp.com.tw/modules/newbb/viewtopic.php?topic_id=67&forum=14
Ok Ok Folks,
you won and I am convinced. Won't open my P800 till spareparts will be available. Have meanwhile ordered Screen-Protector-Foil from Brando.
Should be with me next week. I think using this foil is a better idea 😉
Greetz
Bugfrog
