Change auto-lock time?
6 replies · 5,497 views · Started 10 December 2007
Assuming W960 is almost the same in the menus and system as W950;
Is there, and if yes: how, to change the auto-lock time? Or can you disable it?
Control Panel -> Device -> Backlight:
Here you can enable/disable 'power save', and if enabled, trigger it after 1-30 minuttes.
Enjoy,
-b.
Quite right, that just adjusts when the screen goes completely blank.
I have not yet found a way to adjust the auto-lock time but would also be very interested to hear if there is actually a way of doing it.
U can disable the auto lock on W960i by going in to Meny/Tools or setup/Controlpanel/Security/Lock and then uncheck auto lock box.
Sorry if the names of the menys is written wring but i have my phone in swedish so i just transferd 😊
