N95 8GB built in Help application problem
0 replies · 1,973 views · Started 10 December 2007
Has anybody else noticed a problem a problem with the built-in help application on the N95 8GB?
I get 'Out of memory' errors when trying to access it from either the Help application itself or by pressing options/help inside other applications
It seems to be related with the amount of applications you install, for example on a 'clean (no applications installed) setup it works fine, but as you start to install more applications it gets flakier and flakier (all mine are on the phone memory not the mass memory), after you have installed about 15 applications it stops working all together.
If you un-install a couple of applications it starts working again. Also it doesn't appear to be related to a particular application, it doesn't matter which ones you uninstall, it can be the lasts ones or first ones, nokia or 3rd party, make no difference.
