hi i am kinda in a panic mode at the moment
i just updated to the latest firmware and now the nokia wont boot up.
it just stuck on the white screen saying nokia
how can i fix this?
the Nokia Software Updater told me the update was finish and my nokia did a test mode and now it wont boot up to normal screen
ok strange... took out the battery out again put it back.... then the nokia rebooted.
it allows me to set the time and date and where i from <-- then rebooted by itself
Now its loaded up to the screen.. with "music player" on down right corner
i can also see the battery life but when i try press a button it dosent do anything like its froze
then it rebooted by itself again
First try and reset the phone:
Power it off.
press and keep down the following keys while turning the power on:
The green/talk key, the number '3' and the '*' key
(It's not always easy to do)
Release the keys when you see the phone start to format itself.
If that doesn't work, try to flash it again with NSU. If it really still doesn't work, then you have a couple of choices, take it to a nokia service center and get them to fix it, or find yourself a copy of Phoenix and do the dead phone flash thing.
dchky wrote:First try and reset the phone:
Power it off.
Release the keys when you see the phone start to format itself..
now it keep flashing the white screen saying nokia
