Theme Effects
8 replies · 5,027 views · Started 11 December 2007
I've noticed since V20 in the menu where you choose your theme, under options there is a Theme Effects On/Off setting...
What does this do?
I'd love to knowthe answer to this question too.
I've noticed it on both my N95-1 and N95 8gb, both unbranded, through several firmware versions.
Have tried toggling between the ON/OFF option seemingly to no effect.
If memory serves when you highlight a folder or icon it animates them, like turn to face front of the screen. Its only minor movement though.
Crispy
Isn't that the "Icon Animation" which you access via the options after pressing the menu button?
From Google, I've only found guesses. People generally seem to think that it might be something from FP2 rolled back in to FP1 to allow transitions (or some other theme feature), but it will require a theme with these effects embedded in it.
Me? I've no idea 😊
Burcrim wrote:Isn't that the "Icon Animation" which you access via the options after pressing the menu button?
i don't see icon animation when i press options in the menu. I was looking at a Nokia 6220 Classic yesterday and when you turn off theme efftects on that, it turns off the menu transitions.
Theme effects has been present on my n95 8gb since i got it, on every firmware version but has done nothing. maybe it was just put there in antisipation of future use?! Who knows?...Anyone?
I wonder if there are any themes out there with menu transitions or animated icons.
