Rotating video output
10 replies · 2,571 views · Started 11 December 2007
So here's the idea, we have the N95 here using the video out to a tv to play games. The tv is widescreen and needs to be rotated 90* for the project we're using this for. I'm trying to find out if there is any software for the N95 that can set the tv out to be rotated. Or if there is any hardware application (besides a computer) that can be placed between the phone and the computer.
Thanks.
rottie wrote:Can't you just open the slider the other way?? LOL
No. For one that makes the game controls inaccessible and 2 it still doesn't rotate the screen on the tv the way I'm wanting. The display on the tv needs to rotate.
1) that's not a problem, just use rotateme
2) so do I understand correctly that you want it this way:
up-------down
right?
Then I'm afraid there's no way...
rottie wrote:1) that's not a problem, just use rotateme
up-------down
right?
Like this
rottie wrote:that's not a problem, just use rotateme
I agree. Turn on rotate me, open the phone and turn it to its side to make it rotate the screen, close rotate me, then play your game. Sorted!
Yeah I figured as much.
I'm looking for something now that would take the RCA signal and rotate it. Not having much luck finding such hardware however because I'm not sure what I'm supposed to search for.
If you've got a flat panel like that, isn't there a menu setting on that to do what you want?
surfshag wrote:Wow thats a BIG TomTom LOL
Bet its hard to mount on your w/screen LOL
Gary
It's probably designed to replace your windscreen. Assuming no other cars are on the road, you shouldn't need one 😃
