Help Me!!!!!
3 replies · 2,272 views · Started 11 December 2007
i have a e90 and i forgot my security code. i tried the master code and the default code that is 12345 but i couldnt unlock my fone can anyone help me. it wont even let me start my fone it is stuck on the lock code screen as soon as i start.
Hello,
Just bring it to the closest nokia service centre. They can reset your code for a little amount of money.
Cheers
There is an application that will scan all the possible codes and find your code.. keep searching on the net.. been there, done that 😊 -t
won't a master reset do it??
Just a shot in the dark, but that's what i'd try:
answer button/3/* simultaneously whilst turning on the handset.
What happened to cause this accidental lock?
Are you sure you haven't SIM locked your phone?
If so simply call your operator and request the PUK code to unlock the SIM.
