Putting Garmin Mobile XT on larger SD card?
4 replies · 2,868 views · Started 11 December 2007
Is this possible? Garmin tell me that, if I want to use the N95's inbuilt GPS, I have to use the MicroSD card it comes on. I really don't want to have to swap my cards all the time so is there some way to copy my (genuine and paid for) MicroSD to my 4gb card and still use it with the N95's GPS?
i cant see it making a difference, i would try copying the contents of the garmin card to the 4gig one and see what happens.
I tried that but the icon for Mobile XT changes and when I try to run it it says it's not compatible.
Tried what the other thread suggested but still nothing. I just get file type not supported. I even tried backing up the Garmin card and restoring it to my 4gb card.
Don't know whether it might me because my version is 4.10.60, which is the one supplied on my card.
