hello, my name is Az.
@ Admin/Mods, feel free to butcher if this is too long, i'll let you deceide 😛
This is a revised version of a fix i *discovered while nokia 2nd line are still scratching their a**es. The original version was removed from nokia
discussions because i mentioned NSS, along with many other threads relating to these errors. No matter. here it in a trimmed down format.
My Specs:
N95 (66.01)
v20.0.015
13-11-07
RM-159
nokia sw updater 1.3.2
pc suite 6.84.10.3
statrted with map loader 1.2.1.
all of this was done via usb, as i left my card reader at my friends house.
i have read on several forums that some fixes only work if the SIM is removed. not so. In this case, neither the SIM or sd card were removed once.
My Error(s) with nokia maps/map loader after updating to V20 F/W, in no particular order:
An update to map loader v1.2.1 available,(even though it was 1.2.1 I was using anyway) then update download crashes
media not detedcted
nokia map loader has encountered an error, please try again later
map loader not compatible with the data on your phone
cancelling the offer of the update to 1.2.1 to be taken to map loader, but with only voices to install, and no maps at all.
An error has occured, please try again later.
connection to map server has been interupted, make sure internet connection is working and try again
I tried loads of different ways to get round this each time getting different errors, and i've spent the best part of a week doing so, and since i started,
nokia have removed all relevant threads from the discussions forum. Gotta earn the dollars somehow, eh boys and girls on 2nd line?
while reading through all the various N95 forums trying to fix my error(s), i've found there seems to be alot of people with similar problems with
v20 F/W.
My solution is as follows. THIS IS WHAT WORKED FOR ME IT MIGHT NOT WORK FOR YOU - NO LIABILITIES WHATSOEVER IN ANY WAY OF ANY KIND.
UNINSTALL ALL previous versions of Map Loader and PC Suite. Reboot PC. Re-install them again, and reboot PC again. When you install NML, change the default
install location to C:\NML
BACK UP FROM micro SD Card: - Images,My music, Podcasts etc (if any) via data transfer mode. DONT USE PC SUITE BACKUP FACILITY.
transfer your contacts to your sim directory to back them up without pc suite, then you can copy them back to my contacts later.
Use nokia Software Updater to reinstall phone software
Disconnect from USB data transfer mode and do (what i think is called) a "hard reset", which is:
Hold *+3+Green Call key, and then power on whilst still holding the other 3 buttons.
Phone will reset when complete, set regional info, and time, BUT:
DO NOT INSTALL ANY OTHER APPS YET.
connect usb in pc suite mode.
reinstall MMSync from PC Suite (Help> Reinstal PCS to phone), and reboot phone.
connect usb in data tranasfer mode
Format the memory card in windows via My computer>right-click on N95 mass storage, and format. do a proper format not a quick one, then reboot phone.
Change the RIGHT soft-key shortcut from music player to something else (i used clock), otherwise music player runs in the background and plays hell with the
memory card.
Now, format the card AGAIN using the phone. you may get the msg "the memory card is in use by another application, format anyway?", say yes. You must keep
formatting the card using the phone until it formats WITHOUT the msg about memory card already being in use., otherwise this fix will NEVER work.
Obviously, make sure there are no apps running, (thats how i learned about the music player running in the background) and no data connections active, and
USB is disconnected. eventually, it will format without the waring msg appearing at all. Once the phone has successfuly formatted the card without the
warning msg, you're almost good to go.
Start the Maps application on N95, which is a request of map loader anyway, make sure the app is FULLY started, though you dont need a GPS lock, and then go
to options > exit.
* I THINK* the first time NML is ran, it checks for updates, which causes errors, so the 1st time you run it, DISABLE YOUR INTERNET CONNECTION FIRST. You
may get another error msg, and NML will exit. no matter. re-enable your internet connection, and start NML again. If you're using 1.2.1 or any version
previous to that, you may or may noy be offered to update to the latest version (1.3 at time of writing). accept this update if offered, but this time the
updater should complete without crashing, bringing you up to 1.3.
no errors about media not detected (if you do get that error, just reboot your phone start NML again.)
no errors about compatability
no errors about connectioin to map server
maps and voices available to download and install.
if anyone needs the pc suite, or map loader 1.2.0 that i have used for this fix,
email me on [email protected]
Please let me know how it goes anyone.
