n95 8gb screen menu issues
4 replies · 2,452 views · Started 12 December 2007
Does anyone else with the n95 find that they are having issues with menu text being in the wrong place?
I will upload a picture:
It seems to be happening in quite a lot of 3rd party apps. I wonder if it's cos of the extra screen size, but then that seems gay since the resolution is the same?!?!
Anyone?
Interesting, i just realised that i had changed my font to 'small' in the display settings. I changed it back, and now it's working fine. Wonder if this only happens in 3rd party apps, cos maybe they forgot to sort it out?!
I have this problem in loads of applications, some that are from Nokia too. I do use font magnifier so that's likely a big part of the problem.
I just wish small fonts were actually small.
Hi bigbadnewill
What theme are you using? as to me it looks like a theme issue rather than a device issue, not all theme's are created equal and some can cause all sorts of problems in my experience.
Marc
I also had these problems with my 8GB but I also had it with the default theme. Now it is gone, but I don not know, why.
