Realplayer & Flash
4 replies · 3,811 views · Started 13 December 2007
Please help. I have copied realplayer files on my N95 - they do not work. When I try to open them they say format not supported. Also - when I copy flash files over I cannot find them anywhere in the folders I copied to. Am I doing something wrong? Thanks
Wirelessly posted (Sony Ericsson M600i: Opera/8.01 (J2ME/MIDP; Opera Mini/3.0.6560/1724; en; U; ssr))
For Realplayer:
Are you sure the files can support your phone's realone player ? They may have different encoding, high /unsupported bitrates.
For flash:
Which folder did you copy your files to?
thought the format was the same for realplayer on phone have to check. flash files copied to video downloads directory and also videos. thanks
For flash:
Open flash player ,check the folders that show for your files.
Alternatively, create a new folder with your phone file manager ,place your flash files in this folder. Go open your flash player and search for your flash videos through it.
If there in your gallery video folder.--using your file manager ;they'll probably be in C:/Videos or C:/Nokia/Videos (if in phone memory)
OR
E:/Videos or E:/Nokia/Videos (if in memory card)
Besides, with the built in file manager you can view only C-drive (phone memory) and E-drive (memory card)
ChaosFire wrote:Wirelessly posted (Sony Ericsson M600i: Opera/8.01 (J2ME/MIDP; Opera Mini/3.0.6560/1724; en; U; ssr))
For flash:
OR
I'm sorry but I've done exactly as you said - placed the file in the videos folder on the memory card but it still shows nothing. File type is Flash Video. As for realplayer files don't know whats going on there as when I open RP on the N95 it shows no files yet i have 7 in the folder.
